Saltar al contenido principal
Roku 2 A/C Power Port Replacement
Qué necesitas
  1. Roku 2  A/C Power Port Replacement, Roku 2 Motherboard: paso 1, imagen 1 de 1
    • Heat up the iOpener for 30 seconds in the microwave and place across rubber pads on the back of the device.
    • It may take multiple heats, left for a minute at a time, to properly loosen the glue.
  2. Roku 2  A/C Power Port Replacement: paso 2, imagen 1 de 1
    • Gently use the plastic opening tool to pry the rubber pads off.
  3. Roku 2  A/C Power Port Replacement: paso 3, imagen 1 de 1
    • Remove the four Phillips #000 screws from the bottom of the case.
  4. Roku 2  A/C Power Port Replacement: paso 4, imagen 1 de 1
    • Gently remove the under side of the device.
  5. Roku 2  A/C Power Port Replacement: paso 5, imagen 1 de 1
    • Remove the middle component that is held in place by the top and bottom of the device.
  6. Roku 2  A/C Power Port Replacement: paso 6, imagen 1 de 1
    • Remove the cover over the A/V ports on the front of the device.
  7. Roku 2  A/C Power Port Replacement: paso 7, imagen 1 de 1
    • Remove the board from the plastic enclosure.
  8. Roku 2  A/C Power Port Replacement, A/C Power Port: paso 8, imagen 1 de 1
    • Heat the 3 solder leads on the bottom side of the motherboard opposite of the A/C Port until the point you can pull the port away from the board.
    • To learn more about soldering check out the Soldering Technique Guide.
  9. Roku 2  A/C Power Port Replacement: paso 9, imagen 1 de 1
    • Insert the new A/C power port where the old one was. Gently apply solder to the 3 pins on the bottom side of the mother board to connect it.
Conclusión
david quintana
Miembro Desde 08/27/15
101 Reputación
1 Guía escrita
Equipo
USF Tampa, Team 1-5, Sullivan Fall 2015 Miembro de USF Tampa, Team 1-5, Sullivan Fall 2015
USFT-SULLIVAN-F15S1G5
3 Miembros
7 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 14
Todo El Tiempo: 1,318
