Saltar al contenido principal
Rocketfish RF-WSP313 Speaker Replacement
Qué necesitas
  1. Rocketfish RF-WSP313 Speaker Replacement, Speaker: paso 1, imagen 1 de 1
    • Using the metal spudger, remove the outer cap from the top of the device.
  2. Rocketfish RF-WSP313 Speaker Replacement: paso 2, imagen 1 de 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 cm flathead screws attaching the metal ring to the top of the device.
  3. Rocketfish RF-WSP313 Speaker Replacement: paso 3, imagen 1 de 1
    • Remove the ring and set aside.
  4. Rocketfish RF-WSP313 Speaker Replacement: paso 4, imagen 1 de 1
    • Using the metal spudger, remove the cap from the bottom of the device.
  5. Rocketfish RF-WSP313 Speaker Replacement: paso 5, imagen 1 de 1
    • Using a Phillips # 1 screwdriver, remove the four 1.1 sm screws attaching the metal ring to the bottom of the device.
  6. Rocketfish RF-WSP313 Speaker Replacement: paso 6, imagen 1 de 1
  7. Rocketfish RF-WSP313 Speaker Replacement: paso 7, imagen 1 de 1
    • Using a Phillips # 1 screwdriver, remove the four 1 cm screws from the outside panel. You will do this for each panel; it does not matter which side you start with.
  8. Rocketfish RF-WSP313 Speaker Replacement: paso 8, imagen 1 de 1
    • Using the metal spudger, pry off the side panel. Repeat this step on the other side panel.
  9. Rocketfish RF-WSP313 Speaker Replacement: paso 9, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four 1.1 cm flathead screws from the side of the device. Repeat this step on the other side of the device.
  10. Rocketfish RF-WSP313 Speaker Replacement: paso 10, imagen 1 de 2 Rocketfish RF-WSP313 Speaker Replacement: paso 10, imagen 2 de 2
    • Using the metal spudger, open the device.
  11. Rocketfish RF-WSP313 Speaker Replacement: paso 11, imagen 1 de 2 Rocketfish RF-WSP313 Speaker Replacement: paso 11, imagen 2 de 2
    Herramienta utilizada en este paso:
    Comprar
    • Using your fingers (or a pair of tweezers), disconnect the speaker cord from its socket.
  12. Rocketfish RF-WSP313 Speaker Replacement: paso 12, imagen 1 de 1
    • Using a Phillips #1 screwdriver, remove the four 1.2 cm pan head screws surrounding the speaker.
  13. Rocketfish RF-WSP313 Speaker Replacement: paso 13, imagen 1 de 1
    • Remove the speaker from the device.
Conclusión
Kara Falknor
Miembro Desde 01/25/17
101 Reputación
1 Guía escrita
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 7
Ultimos 30 días: 14
Todo El Tiempo: 584
