Introducción
If the speakers connected to the Rocketfish RF-WHTIB-A system are not producing sound or if the sound is unclear, it could indicate that you have an issue with the sender's speaker input terminal. This guide will show the users a step-by-step on how to remove and replace a faulty speaker's input terminal within the sender.
Qué necesitas
Remove the four rubber tabs from the bottom of the sender.
Use a Phillips #1 screwdriver to unscrew the 10 mm screw, securing the wireless audio module chip.
Desolder the four metallic clasps that attach the panel to the motherboard.
To attach a new speaker input terminal, follow these instructions in reverse order.
2 personas más completaron esta guía.
Un comentario
Where can I get a replacement input terminal?
