Introducción
An LED light not working on the Rocketfish RF-WHTIB-A receiver does not necessarily mean the entire device is broken. It could indicate a problem with the LED light chip inside the device, which controls the LED light function. This guide will direct users step by step to replacing a faulty LED light chip.
Qué necesitas
Remove the 4 rubber tabs on the bottom side of the receiver.
One 10 mm screw is securing the LED 14.14 chip.
Unscrew the chip.
To reassemble your device with the new LED light chip, follow these instructions in reverse order.
Once the receiver has been put back together, plug in the device and initiate the connection mode between the sender and receiver to ensure the new LED light chip has been properly assembled.
2 comentarios
Where do I get the chip???
