Introducción
Replace a Roborock S5 side brush motor to fix the small three-pronged brush on the side when it no longer spins.
Qué necesitas
Power down your Roborock and place it upside down on a flat work surface.
Use a Phillips #2 screwdriver to loosen the captive screw holding the side brush in place.
Remove the 7 screws holding the bottom lid in place.
Lift off the bottom lid.
Remove the 3 screws holding the gearbox in place and lift it out.
Remove the 2 screws of the gearbox.
Carefully lift of the lid (try not to break the clip or loose the gears)
Pull the 2 white plastic gear wheels off to the top (potentially inspect those for damage while it's open anyway).
Remove 2 screws holding the motor in place.
Pull it off to the back.
