Saltar al contenido principal
Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly
Qué necesitas
  1. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly, Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 1, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly, Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 1, imagen 2 de 2
    • This is the make and model number of the device.
  2. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 2, imagen 1 de 1
    • Flip the device upside down.
  3. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 3, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 3, imagen 2 de 2
    • Using pliers, remove the black rubber cover from the bolt.
  4. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 4, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 4, imagen 2 de 2
    • With a 3/8" wrench, remove the nut from the bolt.
    • This may take some force.
  5. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 5, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 5, imagen 2 de 2
    • Remove the cover from the bottom of the machine.
    • This will take lots of force and may require a mix of twisting and pulling.
  6. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 6, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 6, imagen 2 de 2
    • Remove the power cord from the notch on the side.
  7. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 7, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 7, imagen 2 de 2
    • Pull the side up and away from the base of the machine.
  8. Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 8, imagen 1 de 2 Rival Crock-ette 1 Quart Slow Cooker 3205 Disassembly: paso 8, imagen 2 de 2
    • Using pliers, pry the notches on the sides away from the metal and pull until the sides separate.
    • This will require lots of force.
    • The sides of the metal are sharp; be cautious.
Conclusión
Documentos Adjuntos
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 16
Todo El Tiempo: 256
