Saltar al contenido principal
Ring Video Doorbell Speakers Replacement
Qué necesitas
  1. Ring Video Doorbell  Speakers Replacement, Motherboard: paso 1, imagen 1 de 3 Ring Video Doorbell  Speakers Replacement, Motherboard: paso 1, imagen 2 de 3 Ring Video Doorbell  Speakers Replacement, Motherboard: paso 1, imagen 3 de 3
    • Start by using the PH00 Phillips Screwdriver to take out the 6 1 mm screw's on the bottom of the device.
    • Pry open the aluminium plate using the Plastic Opening Tool(s).
    • Remove the 2 1 mm screws using the PH00 Phillips Screwdriver.
  2. Ring Video Doorbell  Speakers Replacement: paso 2, imagen 1 de 3 Ring Video Doorbell  Speakers Replacement: paso 2, imagen 2 de 3 Ring Video Doorbell  Speakers Replacement: paso 2, imagen 3 de 3
    • Pry open the back case as shown using the Plastic Opening Tool.
    • Disconnect the battery from motherboard by carefully pulling up on the connector.
  3. Ring Video Doorbell  Speakers Replacement: paso 3, imagen 1 de 3 Ring Video Doorbell  Speakers Replacement: paso 3, imagen 2 de 3 Ring Video Doorbell  Speakers Replacement: paso 3, imagen 3 de 3
    • Unscrew the 9 1 mm screwdrivers using a PH00 Phillips Screwdriver.
    • Carefully detach the motherboard, from the housing unit using your hands.
  4. Ring Video Doorbell  Speakers Replacement: paso 4, imagen 1 de 2 Ring Video Doorbell  Speakers Replacement: paso 4, imagen 2 de 2
    • Detach the upper part of the motherboard from the bottom, using your hands.
  5. Ring Video Doorbell  Speakers Replacement, Speakers: paso 5, imagen 1 de 1
    • Speakers are two small rectangles located above the button of the doorbell.
  6. Ring Video Doorbell  Speakers Replacement: paso 6, imagen 1 de 1
    • To remove the speakers pry each one out carefully with a plastic opening tool.
Conclusión
Una persona más ha completado esta guía.
Oscar Pascual-Diego
Miembro Desde 02/20/18
112 Reputación
1 Guía escrita
Equipo
USF Tampa, Team S11-G5, Cheng Spring 2018 Miembro de USF Tampa, Team S11-G5, Cheng Spring 2018
USFT-CHENG-S18S11G5
3 Miembros
10 Guías creadas
Un comentario
Where does one get replacement speakers for the 88RG000FC100 ring doorbell?
Jeffrey Lang - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 9
Ultimos 7 días: 29
Ultimos 30 días: 84
Todo El Tiempo: 4,131
