Saltar al contenido principal
Ring Stick Up Cam Speakers Replacement
Qué necesitas
  1. Ring Stick Up Cam Speakers Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the six 6mm Phillips #00 screws from the back of the device.
  2. Ring Stick Up Cam Speakers Replacement: paso 2, imagen 1 de 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Stick Up Cam Speakers Replacement: paso 3, imagen 1 de 1
    • Remove the two 6mm Phillips #00 screws that were under the aluminum plate.
  4. Ring Stick Up Cam Speakers Replacement: paso 4, imagen 1 de 1
    • Pry off the back cover using a plastic opening tool.
  5. Ring Stick Up Cam Speakers Replacement: paso 5, imagen 1 de 1
    • Disconnect the battery power leads using a plastic opening tool.
  6. Ring Stick Up Cam Speakers Replacement: paso 6, imagen 1 de 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  7. Ring Stick Up Cam Speakers Replacement, Camera: paso 7, imagen 1 de 1
    • Remove the three silver 6mm Phillips #00 screws holding the motherboard in the device.
  8. Ring Stick Up Cam Speakers Replacement: paso 8, imagen 1 de 1
    • Disconnect the ribbon connector shown in the photo.
  9. Ring Stick Up Cam Speakers Replacement: paso 9, imagen 1 de 1
    • Remove the motherboard from the device by hand.
  10. Ring Stick Up Cam Speakers Replacement: paso 10, imagen 1 de 1
    • Remove the two black 5mm Phillips #00 screws holding the camera board into the device.
    • Remove the single silver 10mm Phillips #00 screw holding the camera board into the device.
  11. Ring Stick Up Cam Speakers Replacement: paso 11, imagen 1 de 1
    • Remove the three plastic spacers shown in the photo by hand.
  12. Ring Stick Up Cam Speakers Replacement: paso 12, imagen 1 de 1
    • Carefully disconnect the camera board from the daughterboard by sliding a plastic opening tool between the camera board and the daughterboard.
  13. Ring Stick Up Cam Speakers Replacement: paso 13, imagen 1 de 1
    • Lift the camera board out of the housing using your hand.
  14. Ring Stick Up Cam Speakers Replacement, Microphone: paso 14, imagen 1 de 1
    • Remove the six silver 4.5mm Phillips #00 screws holding the daughterboard into the device.
  15. Ring Stick Up Cam Speakers Replacement: paso 15, imagen 1 de 1
    • Use a plastic opening tool to carefully pry the microphone from the housing.
  16. Ring Stick Up Cam Speakers Replacement: paso 16, imagen 1 de 1
    • Use your hands to remove the daughterboard containing the microphone from the housing.
  17. Ring Stick Up Cam Speakers Replacement, Speakers: paso 17, imagen 1 de 1
    • Using a plastic opening tool, remove both of the speakers.
Conclusión
Chunyue Liu
Miembro Desde 02/06/19
273 Reputación
2 Guías creadas
Equipo
UC Davis, Team S18-G3, Lore Winter 2019 Miembro de UC Davis, Team S18-G3, Lore Winter 2019
UCD-LORE-W19S18G3
3 Miembros
8 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 14
Todo El Tiempo: 1,075
