Saltar al contenido principal
Ring Spotlight Cam Battery Motion Detector Replacement
Qué necesitas
  1. Ring Spotlight Cam Battery Motion Detector Replacement, Motion Detector: paso 1, imagen 1 de 1
    • Turn Ring Spotlight Cam to the posterior side and flip upside down
  2. Ring Spotlight Cam Battery Motion Detector Replacement: paso 2, imagen 1 de 1
    • Press down on top button and open upward
  3. Ring Spotlight Cam Battery Motion Detector Replacement: paso 3, imagen 1 de 1
    • Make sure to remove the batteries in the Spotlight cam before proceeding with this step!
    • Open the Spotlight Cam upward and remove the two screws with a Phillips #1 screwdriver.
  4. Ring Spotlight Cam Battery Motion Detector Replacement: paso 4, imagen 1 de 1
    • Remove the two screws down the middle and lift the middle component off
  5. Ring Spotlight Cam Battery Motion Detector Replacement: paso 5, imagen 1 de 1
    • Remove the remaining 10 screws that are around the border under the tape.
  6. Ring Spotlight Cam Battery Motion Detector Replacement: paso 6, imagen 1 de 1
    • Gently close the top of the lid
  7. Ring Spotlight Cam Battery Motion Detector Replacement: paso 7, imagen 1 de 1
    • Remove the top lid and replace the LED light
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 35
Todo El Tiempo: 1,890
