Saltar al contenido principal
Ring Spotlight Cam Battery Lights Replacement
Qué necesitas
  1. Ring Spotlight Cam Battery Lights Replacement, Lights: paso 1, imagen 1 de 1
    • Remove the top plastic pad by peeling it off with a metal spudger.
  2. Ring Spotlight Cam Battery Lights Replacement: paso 2, imagen 1 de 2 Ring Spotlight Cam Battery Lights Replacement: paso 2, imagen 2 de 2
    • Remove the 7 PH00 screws around the four corners with PH00 of the lid.
  3. Ring Spotlight Cam Battery Lights Replacement: paso 3, imagen 1 de 1
    • Use the metal spudger set to break the glue lining and the motion sensor will pop out.
Conclusión
6 personas más completaron esta guía.
2 comentarios
this showed nothing about replacing the light bulb
Martha “purplemarty” Ewell - Contestar
This is not a complete how to. The directions stop in the middle and don't show the replacement of the LEDs. Also no parts link for the replacement LED strips
Matt Newman - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 21
Ultimos 30 días: 98
Todo El Tiempo: 4,872
