Saltar al contenido principal
Ring Outdoor Security Cam Speakers Replacement
Qué necesitas
  1. Ring Outdoor Security Cam Speakers Replacement, Speakers: paso 1, imagen 1 de 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Speakers Replacement: paso 2, imagen 1 de 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Speakers Replacement: paso 3, imagen 1 de 1
    • Use an opening tool to pry the back plate off of the device.
  4. Ring Outdoor Security Cam Speakers Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Speakers Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Speakers Replacement: paso 6, imagen 1 de 1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the 3 silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Speakers Replacement: paso 7, imagen 1 de 1
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Speakers Replacement: paso 8, imagen 1 de 2 Ring Outdoor Security Cam Speakers Replacement: paso 8, imagen 2 de 2
    • Remove the silver 5vmm Phillips #00 screw, and the two 10mm Phillips #00 from the next circuit board.
    • Remove the 3 plastic spacers on the device.
  9. Ring Outdoor Security Cam Speakers Replacement: paso 9, imagen 1 de 3 Ring Outdoor Security Cam Speakers Replacement: paso 9, imagen 2 de 3 Ring Outdoor Security Cam Speakers Replacement: paso 9, imagen 3 de 3
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
  10. Ring Outdoor Security Cam Speakers Replacement: paso 10, imagen 1 de 2 Ring Outdoor Security Cam Speakers Replacement: paso 10, imagen 2 de 2
    • Remove the six silver 4.5 mm Phillips #00 screws holding the daughterboard into the device.
    • Then use the plastic prying tool to remove the final daughterboard and attached microphone
  11. Ring Outdoor Security Cam Speakers Replacement: paso 11, imagen 1 de 1
    • Using the plastic prying tool pop out the speakers on the back of the daughterboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 105
