Saltar al contenido principal
Ring Outdoor Security Cam Camera Replacement
Qué necesitas
  1. Ring Outdoor Security Cam Camera Replacement, Camera: paso 1, imagen 1 de 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Camera Replacement: paso 2, imagen 1 de 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Camera Replacement: paso 3, imagen 1 de 1
    • Use an opening tool to pry the back plate off of the device.
  4. Ring Outdoor Security Cam Camera Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Camera Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
  6. Ring Outdoor Security Cam Camera Replacement: paso 6, imagen 1 de 1
    • Disconnect the ribbon cable carefully at the bottom of the device.
    • Remove the three silver 6 mm Phillips #00 screws from the motherboard.
  7. Ring Outdoor Security Cam Camera Replacement: paso 7, imagen 1 de 1
    • Pull the top of the motherboard up and out of the device.
  8. Ring Outdoor Security Cam Camera Replacement: paso 8, imagen 1 de 2 Ring Outdoor Security Cam Camera Replacement: paso 8, imagen 2 de 2
    • Remove the silver 5 mm Phillips #00 screw, and the two 10 mm Phillips #00 from the next motherboard.
    • Then remove the three plastic spacers on the device.
  9. Ring Outdoor Security Cam Camera Replacement: paso 9, imagen 1 de 3 Ring Outdoor Security Cam Camera Replacement: paso 9, imagen 2 de 3 Ring Outdoor Security Cam Camera Replacement: paso 9, imagen 3 de 3
    • Pry the motherboard out with a plastic opening tool.
    • Flip the device over and then carefully press on the camera lens to remove the camera and the attached mother board from the device.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 30
Todo El Tiempo: 178
