Saltar al contenido principal
Ring Outdoor Security Cam Battery Replacement
Qué necesitas
  1. Ring Outdoor Security Cam Battery Replacement, Battery: paso 1, imagen 1 de 1
    • Remove the six 6 mm Phillips #00 screws from the back on the device.
  2. Ring Outdoor Security Cam Battery Replacement: paso 2, imagen 1 de 1
    • Pry off the aluminum plate using a plastic opening tool.
  3. Ring Outdoor Security Cam Battery Replacement: paso 3, imagen 1 de 1
    • Using the same tool pry the back plate off of the device.
  4. Ring Outdoor Security Cam Battery Replacement: paso 4, imagen 1 de 1
    • Disconnect the battery power leads using a plastic opening tool.
  5. Ring Outdoor Security Cam Battery Replacement: paso 5, imagen 1 de 1
    • Use a plastic opening tool to loosen the adhesive holding the battery in place and remove the battery by hand.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 26
Todo El Tiempo: 189
