Introducción
The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
Herramientas
Partes
No se especificaron partes.
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Identify the LED light. Look for the component with clear casing with two wires attached located toward the bottom of the driver.
Casi Terminas!
Conclusión
