Saltar al contenido principal
Repara tus cosas
Derecho a reparar
Tienda
Introducción
The trigger is a multi-speed switch and requires replacing the whole assembly. Soldering is necessary for this guide. Please familiarize yourself with the iFixit guide on Soldering before starting.
  1. Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
    • The rubber cover is securely attached to the housing so some force is necessary.
    • When putting the rubber cover back, remember that its orientation is important. Rotate the casing until it fits onto the housing with no gaps between it and the clear cover.
  2. Remove the plastic cover with your hands. The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off. Remove the plastic cover with your hands. The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off.
    • Remove the plastic cover with your hands. The plastic cover should be much easier to remove than the rubber cover. There is no need to force it off.
  3. Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver. Use a firm grip to peel the the back panel off. It is sealed tight and requires a good amount of force to remove. Use a firm grip to peel the the back panel off. It is sealed tight and requires a good amount of force to remove.
    • Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
    • Use a firm grip to peel the the back panel off. It is sealed tight and requires a good amount of force to remove.
  4. Unscrew the eight 15 mm T10 Torx screws from the housing The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead use a conventional screwdriver that fits.
    • Unscrew the eight 15 mm T10 Torx screws from the housing
    • The screw hole located nearest the battery port is deep and small. Most screwdrivers with replaceable bits will not fit into the hole. Instead use a conventional screwdriver that fits.
  5. ABRIR TODAS LAS PESTAÑAS
    Kits de actualización de RAM para Mac
    Compra kits
    Suficiente RAM
    para todas las pestañas
    Compra kits
  6. Place the driver flat on a table before completely separating the two halves of the housing so components don't fall out during opening.
    • Place the driver flat on a table before completely separating the two halves of the housing so components don't fall out during opening.
    • Pry apart the two halves of the housing at the back side of the driver using the metal spudger .
    • The housing is easier to remove if you pry from multiple sides.
  7. Do not remove the direction switch. It isn't necessary. Pull out all electrical components from housing by hand. First, lift out the motor. Next, follow the wires, lifting out components until all components are outside of the housing.
    • Do not remove the direction switch. It isn't necessary.
    • Pull out all electrical components from housing by hand. First, lift out the motor. Next, follow the wires, lifting out components until all components are outside of the housing.
    • With two exceptions all of the components should come out of their respective slots with ease and require little force to lift out. The circuit board located nearest the battery pack and the LED light will be hard to pull out.
    • When reassembling remember to precisely place all components in their correct slots with their correct orientations.
  8. Identify the LED light. Look for the component with clear casing with two wires attached located toward the bottom of the driver.
    • Identify the LED light. Look for the component with clear casing with two wires attached located toward the bottom of the driver.
  9. Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED. Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED. Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED.
    • Cut the pink and white wire attached to the LED as a little more than a quarter inch from the LED.
  10. Strip the wires on the LED by a quarter inch.
    • Strip the wires on the LED by a quarter inch.
  11. Strip the wires that were connected to the LED on the circuit board about a quarter inch. Strip the wires that were connected to the LED on the circuit board about a quarter inch.
    • Strip the wires that were connected to the LED on the circuit board about a quarter inch.
  12. Solder the new LED with striped wires to the wire attached to the circuit board.
    • Solder the new LED with striped wires to the wire attached to the circuit board.
    • Wrap the newly soldered connection with electrical tape to ensure that the circuit isn't shorted.
Conclusión
Sean Liston
Miembro Desde 28/04/15
275 Reputación
2 Guías creadas
Equipo
Cal Poly, Team 15-5, Amido Spring 2015 Miembro de Cal Poly, Team 15-5, Amido Spring 2015
CPSU-AMIDO-S15S15G5
4 Miembros
12 Guías creadas
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 17
Todo El Tiempo: 566
