Saltar al contenido principal
Ridgid R82005 Trigger Switch Replacement
Qué necesitas
  1. Ridgid R82005 Trigger Switch Replacement, Trigger Switch: paso 1, imagen 1 de 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
    • Unscrew the M5x18.5mm screw if belt clip is attached.
  2. Ridgid R82005 Trigger Switch Replacement: paso 2, imagen 1 de 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic spudger.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Trigger Switch Replacement: paso 3, imagen 1 de 3 Ridgid R82005 Trigger Switch Replacement: paso 3, imagen 2 de 3 Ridgid R82005 Trigger Switch Replacement: paso 3, imagen 3 de 3
    • Remove the top half of the Housing Assembly.
    • Keep track of where the wires lead from the motor assembly to trigger switch.
    • Remove all internal components.
  4. Ridgid R82005 Trigger Switch Replacement: paso 4, imagen 1 de 3 Ridgid R82005 Trigger Switch Replacement: paso 4, imagen 2 de 3 Ridgid R82005 Trigger Switch Replacement: paso 4, imagen 3 de 3
    • Motor Assembly/Gearbox and Trigger Switch removed from Housing Assembly.
    • Desolder the black wire connected to the motor.
    • Flip Trigger Switch and desolder red wire.
    • To learn how to solder, use our How to Solder and Desolder Connections guide.
Conclusión
2 personas más completaron esta guía.
Alex Cominos
Miembro Desde 02/14/19
376 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2019 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 13
Todo El Tiempo: 435
