Saltar al contenido principal
Ridgid R82005 LED Light Replacement
Qué necesitas
  1. Ridgid R82005 LED Light Replacement, Housing Assembly: paso 1, imagen 1 de 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 LED Light Replacement: paso 2, imagen 1 de 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 LED Light Replacement: paso 3, imagen 1 de 2 Ridgid R82005 LED Light Replacement: paso 3, imagen 2 de 2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 LED Light Replacement: paso 4, imagen 1 de 2 Ridgid R82005 LED Light Replacement: paso 4, imagen 2 de 2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
  5. Ridgid R82005 LED Light Replacement, LED Light: paso 5, imagen 1 de 2 Ridgid R82005 LED Light Replacement, LED Light: paso 5, imagen 2 de 2
    • Unplug the LED connector gently.
Conclusión
2 personas más completaron esta guía.
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2019 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 278
