Saltar al contenido principal
Ridgid R82005 Housing Assembly Replacement
Qué necesitas
  1. Ridgid R82005 Housing Assembly  Replacement, Housing Assembly: paso 1, imagen 1 de 1
    • Eject the battery from the drill.
    • Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
  2. Ridgid R82005 Housing Assembly  Replacement: paso 2, imagen 1 de 1
    • Push the metallic Housing Connecting clip out with flat side of the plastic opening tool.
    • Eject battery before attempting this step.
  3. Ridgid R82005 Housing Assembly  Replacement: paso 3, imagen 1 de 2 Ridgid R82005 Housing Assembly  Replacement: paso 3, imagen 2 de 2
    • Remove the top half of the Housing Assembly.
  4. Ridgid R82005 Housing Assembly  Replacement: paso 4, imagen 1 de 2 Ridgid R82005 Housing Assembly  Replacement: paso 4, imagen 2 de 2
    • Grasp carefully the top and bottom of drill components.
    • LED light needs to be manually removed.
    • Lift and transfer, as a whole, the drill components from the old housing assembly to the new housing.
    • Make sure all drill components fit properly in the grooves of new Housing Assembly.
Conclusión
To reassemble your device, follow these instructions in reverse order. Also reinsert the battery to make sure the drill has power.
2 personas más completaron esta guía.
Alex Cominos
Miembro Desde 02/14/19
376 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S1-G2, Leahy Spring 2019 Miembro de USF Tampa, Team S1-G2, Leahy Spring 2019
USFT-LEAHY-S19S1G2
4 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 12
Todo El Tiempo: 254
