Introducción
The Ridgid R82005 speed gear switch alters the amount of power intended for specific drill-driver bits and the type of materials manipulated by operators. Forcing this tool to produce torque beyond the limits of a speed gear can cause jams that compromise the drill's versatility.
Qué necesitas
Eject the battery from the drill.
Unscrew the seven M3x15.3mm screws, with the 2mm hex screwdriver bit, that secures the Housing Assembly.
Remove the 2 speed gear selector by carefully lifting it out of the housing, making sure it is free from the speed switch rail.
4 personas más completaron esta guía.
