Saltar al contenido principal
Ridgid R2611 Switch Bracket Replacement
Qué necesitas
  1. Ridgid R2611 Switch Bracket Replacement, Switch Bracket: paso 1, imagen 1 de 1
    • Remove the seven 2.5 mm screws on the top of the sander using the Torx T15 screwdriver.
  2. Ridgid R2611 Switch Bracket Replacement: paso 2, imagen 1 de 1
    • Remove the top of the sander and put to the side.
  3. Ridgid R2611 Switch Bracket Replacement: paso 3, imagen 1 de 1
    • Use the screwdriver to unscrew the two #6-19 X 5/8 in screws holding down the outlet cord.
  4. Ridgid R2611 Switch Bracket Replacement: paso 4, imagen 1 de 1
    • Remove the cord from the handle.
  5. Ridgid R2611 Switch Bracket Replacement: paso 5, imagen 1 de 1
    • Remove the outer plastic piece holding down the white and black wires.
  6. Ridgid R2611 Switch Bracket Replacement: paso 6, imagen 1 de 1
    • Unplug the two connecting pieces that hold wires.
  7. Ridgid R2611 Switch Bracket Replacement: paso 7, imagen 1 de 1
    • Using the screwdrivers, unscrew the four #6-19 X 5/8 in screws on rectangular block.
  8. Ridgid R2611 Switch Bracket Replacement: paso 8, imagen 1 de 1
    • Remove the black and white wires by pulling out.
  9. Ridgid R2611 Switch Bracket Replacement: paso 9, imagen 1 de 1
    • Put the screwdriver in the holes to release remaining two wires.
  10. Ridgid R2611 Switch Bracket Replacement: paso 10, imagen 1 de 1
    • Remove the two remaining wires from switch, leaving the switch freed.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 298
