Saltar al contenido principal
Ridgid R2601 Bearing Replacement
Qué necesitas
  1. Ridgid R2601 Bearing Replacement, Bearing: paso 1, imagen 1 de 1
    • Turn the sander upside down so that the base faces you.
    • Remove the four 6.4 mm screws from the bottom of the base using a Torx T-25 screwdriver.
  2. Ridgid R2601 Bearing Replacement: paso 2, imagen 1 de 1
    • Remove the base.
  3. Ridgid R2601 Bearing Replacement: paso 3, imagen 1 de 1
    • Remove the 10 mm screw from the center of the bearing using a Torx T-20 screwdriver.
  4. Ridgid R2601 Bearing Replacement: paso 4, imagen 1 de 1
    • Remove the bearing.
Conclusión
4 comentarios
What is the bearing size?
Dagan Larson - Contestar
The actual bearing appears to be an R002RS.
ID 15mm
OD 32mm
Width: 9mm
I used a large socket to push the bearing out of the squarish bracket. The bearing needs to be pushed out from top to bottom (as it would be oriented when the sander is sitting upright on a surface).
I placed the socket inside the opening in the top, and put screws into the bottom (I happened to have some longer screws with the same thread pitch) to provide clearance for the bearing to come out. Then I pressed it with a vise. Tapping the socket with a hammer would also work.
Joe Porkka - Contestar
Shouldn't the title be "How to remove a bearing housing"? You don't give any instructions on how to actually remove the bearing from the housing, nor how to insert a new bearing into the housing and reassembly.
I'm sorry, but it feels like you got part way into the instructions, got bored and said, "eh, it's good enough."
Joseph Brzezicki - Contestar
How do you know if the bearings bad? Mine spins ok seems even, no sounds coming from it, the pad spins really slow if I put any pressure, even just with the weight of the sander
Nick Wilkens - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 1,974
