Saltar al contenido principal
Ridgid GEN5X R8653 Base Assembly Replacement
Qué necesitas
  1. Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: paso 1, imagen 1 de 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: paso 1, imagen 2 de 3 Ridgid GEN5X R8653 Base Assembly Replacement, Base Assembly: paso 1, imagen 3 de 3
    • Always disconnect battery and use gloves when working with the saw blade. Failure to do so may result in damage or injury!
    • Remove the supplied Allen wrench from it's nesting space in the front of the handle.
    • Depress and hold the spindle lock button located between the handle and blade shroud.
    • Using the supplied 6mm Allen Wrench, unscrew the bolt securing the blade and remove the blade.
  2. Ridgid GEN5X R8653 Base Assembly Replacement: paso 2, imagen 1 de 3 Ridgid GEN5X R8653 Base Assembly Replacement: paso 2, imagen 2 de 3 Ridgid GEN5X R8653 Base Assembly Replacement: paso 2, imagen 3 de 3
    • Remove seven 6mm T20 Torx screws located around base of saw.
    • Pull base assembly away from saw.
    • These screws are very tight and need significant force to be removed.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 13
Todo El Tiempo: 251
