Saltar al contenido principal
Ridgid GEN5X R8642 Blade Clamp Assembly Replacement
Qué necesitas
  1. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement, Blade Clamp Assembly: paso 1, imagen 1 de 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 2, imagen 1 de 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 3, imagen 1 de 2 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 3, imagen 2 de 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 4, imagen 1 de 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 5, imagen 1 de 1
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 6, imagen 1 de 2 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 6, imagen 2 de 2
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 7, imagen 1 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 7, imagen 2 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 7, imagen 3 de 3
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 8, imagen 1 de 2 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 8, imagen 2 de 2
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 9, imagen 1 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 9, imagen 2 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 9, imagen 3 de 3
    • Remove the orbital switch by pulling straight up on it.
    • Be careful to not lose the spring and pin that is inside of the switch.
  10. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 10, imagen 1 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 10, imagen 2 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 10, imagen 3 de 3
    • Remove the gear assembly by pulling it straight up.
  11. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 11, imagen 1 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 11, imagen 2 de 3 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 11, imagen 3 de 3
    • Pull the pin holding the metal guide housing in place.
    • Slide the metal guide housing back off the gear assembly.
  12. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 12, imagen 1 de 2 Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 12, imagen 2 de 2
    • Remove the guide bushing by pulling up on it.
    • Then slide the pin out that holds the gear assembly and blade clamp assembly.
  13. Ridgid GEN5X R8642 Blade Clamp Assembly Replacement: paso 13, imagen 1 de 1
    • Slide the blade clamp assembly off the gear assembly.
Conclusión
2 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 1,626
