Saltar al contenido principal
Ridgid GEN5X R8642 Motor Replacement
Qué necesitas
  1. Ridgid GEN5X R8642  Motor Replacement, Motor Replacement: paso 1, imagen 1 de 1
    • Remove the plastic tab holding the handle cover in place by prying upward with the spudger until the tab pops off.
  2. Ridgid GEN5X R8642  Motor Replacement: paso 2, imagen 1 de 1
    • Remove the handle cover by pulling it towards the front of the saw.
    • The grip can sometimes become stuck and may require a decent amount of force to remove.
  3. Ridgid GEN5X R8642  Motor Replacement: paso 3, imagen 1 de 2 Ridgid GEN5X R8642  Motor Replacement: paso 3, imagen 2 de 2
    • Use a T20 Torx screwdriver to remove the nine M4 X 16mm screws from the plastic housing.
  4. Ridgid GEN5X R8642  Motor Replacement: paso 4, imagen 1 de 1
    • Use a JIS #1 screwdriver to remove the two M4 x 25mm screws on both sides of the metal housing.
  5. Ridgid GEN5X R8642  Motor Replacement: paso 5, imagen 1 de 2 Ridgid GEN5X R8642  Motor Replacement: paso 5, imagen 2 de 2
    • Remove one half of the plastic housing using a spudger so that the internal system is exposed.
  6. Ridgid GEN5X R8642  Motor Replacement: paso 6, imagen 1 de 2 Ridgid GEN5X R8642  Motor Replacement: paso 6, imagen 2 de 2
    • Remove the one 16mm T20 screw that holds the grip support onto the saw.
  7. Ridgid GEN5X R8642  Motor Replacement: paso 7, imagen 1 de 3 Ridgid GEN5X R8642  Motor Replacement: paso 7, imagen 2 de 3 Ridgid GEN5X R8642  Motor Replacement: paso 7, imagen 3 de 3
    • Remove the five T20 Torx screws from the gear assembly cover and pull the cover off.
  8. Ridgid GEN5X R8642  Motor Replacement: paso 8, imagen 1 de 2 Ridgid GEN5X R8642  Motor Replacement: paso 8, imagen 2 de 2
    • Carefully remove the motor making sure not to harm any of the wires that are attached. Place motor gently out of the way.
  9. Ridgid GEN5X R8642  Motor Replacement: paso 9, imagen 1 de 1
    • Remove the plastic wire covers to the red and black connections on the switch assembly.
    • When you remove the wire covers, you should be able to see the solder on the wires.
    • Desolder the connections on both the red and black wire using a soldering iron.
    • Once the solder is removed, pull out the wires with the battery port attached to the wires.
  10. Ridgid GEN5X R8642  Motor Replacement: paso 10, imagen 1 de 1
    • Remove the soldered connection from the switch assembly.
  11. Ridgid GEN5X R8642  Motor Replacement: paso 11, imagen 1 de 2 Ridgid GEN5X R8642  Motor Replacement: paso 11, imagen 2 de 2
    • Solder both connections of the new motor replacement to the switch assembly.
Conclusión
To reassemble your device follow these instructions in reverse order.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 410
