Introducción
Use this guide if your drill’s gears are broken. You will need the tools listed below in order to complete this guide.
Qué necesitas
Orient the drill to have the side with the screws facing up.
Using the Torx T10 screwdriver, remove the eight 4.0mm screws from the face of the drill.
Locate the selector switch.
Unhook the selector switch from the small silver wire located near the top of the drill.
2 personas más completaron esta guía.
