Saltar al contenido principal
Ridgid Circular Saw R3205 Switch Replacement
Qué necesitas
  1. Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: paso 1, imagen 1 de 3 Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: paso 1, imagen 2 de 3 Ridgid Circular Saw R3205 Switch Replacement, Motor Housing with Handle Assembly: paso 1, imagen 3 de 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Switch Replacement: paso 2, imagen 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 2, imagen 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 2, imagen 3 de 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Switch Replacement: paso 3, imagen 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 3, imagen 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 3, imagen 3 de 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Switch Replacement: paso 4, imagen 1 de 2 Ridgid Circular Saw R3205 Switch Replacement: paso 4, imagen 2 de 2
    • The motor housing assembly can now be removed from the rest of the saw.
  5. Ridgid Circular Saw R3205 Switch Replacement, Switch: paso 5, imagen 1 de 1
    • Remove 5 Torx 20 (#8-16 x 5/8 in.) screws from the outer handle.
  6. Ridgid Circular Saw R3205 Switch Replacement: paso 6, imagen 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 6, imagen 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 6, imagen 3 de 3
    • Remove the outer handle.
  7. Ridgid Circular Saw R3205 Switch Replacement: paso 7, imagen 1 de 1
    • Using a phillips head screwdriver remove the (M4 x 12 mm) screw holding the switch in place.
  8. Ridgid Circular Saw R3205 Switch Replacement: paso 8, imagen 1 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 8, imagen 2 de 3 Ridgid Circular Saw R3205 Switch Replacement: paso 8, imagen 3 de 3
    • Remove the wires that attach to the power cord.
Conclusión
Joshua Caron
Miembro Desde 04/05/19
792 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 5
Todo El Tiempo: 728
