Saltar al contenido principal
Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement
Qué necesitas
  1. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: paso 1, imagen 1 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: paso 1, imagen 2 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement, Motor Housing with Handle Assembly: paso 1, imagen 3 de 3
    • Remove the brush assembly with a flat head screwdriver.
  2. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 2, imagen 1 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 2, imagen 2 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 2, imagen 3 de 3
    • Use a T25 Torx screwdriver to remove 3 (M5 x 58 mm) screws.
  3. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 3, imagen 1 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 3, imagen 2 de 3 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 3, imagen 3 de 3
    • Use a T20 Torx screwdriver to remove the (1/4-20 x 0.66 in.) screw.
    • After removing the (1/4-20 x 0.66 in.) screw the lever assembly can be unscrewed from the (1/4-20 x 0.66 in.) screw.
  4. Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 4, imagen 1 de 2 Ridgid Circular Saw R3205 Motor Housing with Handle Assembly Replacement: paso 4, imagen 2 de 2
    • The motor housing assembly can now be removed from the rest of the saw.
Conclusión
Joshua Caron
Miembro Desde 04/05/19
792 Reputación
5 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 354
