Saltar al contenido principal
Ridgid Circular Saw R3205 Lower Blade Guard Replacement
Qué necesitas
  1. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: paso 1, imagen 1 de 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Blade: paso 1, imagen 2 de 2
    • Press the black spindle lock and hold it down.
    • While keeping the spindle lock pressed down use a 6mm allen wrench to remove the 5/16-18 x 0.55 inch screw.
  2. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 2, imagen 1 de 1
    • Release the spindle lock and remove the outer flange by lifting it off the output shaft.
  3. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 3, imagen 1 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 3, imagen 2 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 3, imagen 3 de 3
    • With the outer flange removed retract the lower blade guard into the upper blade guard housing by pushing on the black lever.
    • Slide the blade out of from the bottom of the saw.
  4. Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: paso 4, imagen 1 de 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement, Lower Blade Guard: paso 4, imagen 2 de 2
    • Use a prying tool or your fingers to remove the inner flange.
  5. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 5, imagen 1 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 5, imagen 2 de 3 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 5, imagen 3 de 3
    • Remove the external retaining ring with a screwdriver by expanding it and then prying it out.
  6. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 6, imagen 1 de 1
    • After removing the external retaining ring, remove (OD50 x ID42 x 0.8t) washer.
  7. Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 7, imagen 1 de 2 Ridgid Circular Saw R3205 Lower Blade Guard Replacement: paso 7, imagen 2 de 2
    • Remove the lower blade guard after removing the washer.
Conclusión
3 personas más completaron esta guía.
Joshua Caron
Miembro Desde 04/05/19
792 Reputación
5 Guías creadas
Equipo
Un comentario
Thank you so VERY much! I was stuck and this was perfectly described!
Chris Bishop - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 24
Todo El Tiempo: 1,977
