Saltar al contenido principal
Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement
Qué necesitas
  1. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Ridgid R860054 Disassembly: paso 1, imagen 1 de 2 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Ridgid R860054 Disassembly: paso 1, imagen 2 de 2
    • Using a T10 Torx security bit, remove the ten screws from the housing assembly.
    • All of the casing screws are the same length and require the same bit.
  2. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 2, imagen 1 de 2 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 2, imagen 2 de 2
    • Separate one half of the drill casing from the other by gently pulling both halves apart.
    • Once one half of the casing is removed, be careful! If the components are directed towards the ground, they could fall out.
  3. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 3, imagen 1 de 3 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 3, imagen 2 de 3 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 3, imagen 3 de 3
    • Remove the plastic speed switch and forward/reverse switch by softly lifting them from the casing.
    • Remove the internal components of the drill by lightly pulling on the drill chuck.
    • All of the other electronic components are attached to the chuck, and will come out with it.
  4. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 4, imagen 1 de 1
    • The main section of the drill should have the trigger, light indicator, and battery prongs all connected via wire. There should be two plastic switches separated from the rest of the body.
  5. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Reverse and Forward Switch: paso 5, imagen 1 de 2 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement, Reverse and Forward Switch: paso 5, imagen 2 de 2
    • Remove the broken forward and backward switch by lifting it off of the trigger.
  6. Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 6, imagen 1 de 2 Ridgid Brushless Drill Driver R860054 Reverse and Forward Switch Replacement: paso 6, imagen 2 de 2
    • Replace the reverse switch with a new a switch.
    • Ensure the switch is inserted properly.
Conclusión
Una persona más ha completado esta guía.
gage.anastasio
Miembro Desde 03/15/23
339 Reputación
3 Guías creadas
Equipo
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 13
Todo El Tiempo: 150
