Saltar al contenido principal
Ridgid Angle Grinder R10202 Motor Housing Replacement
Qué necesitas
  1. Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: paso 1, imagen 1 de 2 Ridgid Angle Grinder R10202 Motor Housing Replacement, Carbon Brush: paso 1, imagen 2 de 2
    • Use a flathead screwdriver to unscrew the brush holder cap.
  2. Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 2, imagen 1 de 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 2, imagen 2 de 2
    • Using your fingers, gently lift the carbon brush up and out of its housing.
    • Repeat these steps to remove the other carbon brush on the opposing side.
  3. Ridgid Angle Grinder R10202 Motor Housing Replacement, Motor Housing: paso 3, imagen 1 de 1
    • Unscrew the side handle assembly from the gear housing assembly by hand.
  4. Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 4, imagen 1 de 1
    • Unscrew the clamp nut and the backing flange from the output shaft assembly.
    • You can do this by hand or use a spanner wrench which should be provided in the manufacturers box.
  5. Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 5, imagen 1 de 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 5, imagen 2 de 2
    • Push in the guard lever and twist the guard until it aligns with the slots on the output shaft assembly.
    • There are two arrows that should align before you attempt to pull the pieces apart.
  6. Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 6, imagen 1 de 1
    • Lift the guard away from the output shaft assembly.
  7. Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 7, imagen 1 de 2 Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 7, imagen 2 de 2
    • Using a T25 Torx screwdriver, unscrew the four M5 X 28mm Torx screws.
  8. Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 8, imagen 1 de 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 8, imagen 2 de 3 Ridgid Angle Grinder R10202 Motor Housing Replacement: paso 8, imagen 3 de 3
    • Grab the handle assembly and the gear housing assembly and gently pull apart.
    • Slowly pull the gear housing assembly out being careful not to damage the motor against the inside of the motor housing.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 4
Ultimos 30 días: 19
Todo El Tiempo: 840
