Saltar al contenido principal
Ricoh YF-20 Super Lens Replacement
Qué necesitas
  1. Ricoh YF-20 Super Lens Replacement, Front Cover: paso 1, imagen 1 de 2 Ricoh YF-20 Super Lens Replacement, Front Cover: paso 1, imagen 2 de 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Replacement: paso 2, imagen 1 de 3 Ricoh YF-20 Super Lens Replacement: paso 2, imagen 2 de 3 Ricoh YF-20 Super Lens Replacement: paso 2, imagen 3 de 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Replacement: paso 3, imagen 1 de 3 Ricoh YF-20 Super Lens Replacement: paso 3, imagen 2 de 3 Ricoh YF-20 Super Lens Replacement: paso 3, imagen 3 de 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Replacement: paso 4, imagen 1 de 3 Ricoh YF-20 Super Lens Replacement: paso 4, imagen 2 de 3 Ricoh YF-20 Super Lens Replacement: paso 4, imagen 3 de 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Replacement: paso 5, imagen 1 de 2 Ricoh YF-20 Super Lens Replacement: paso 5, imagen 2 de 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Replacement: paso 6, imagen 1 de 3 Ricoh YF-20 Super Lens Replacement: paso 6, imagen 2 de 3 Ricoh YF-20 Super Lens Replacement: paso 6, imagen 3 de 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Lens Replacement, Lens: paso 7, imagen 1 de 3 Ricoh YF-20 Super Lens Replacement, Lens: paso 7, imagen 2 de 3 Ricoh YF-20 Super Lens Replacement, Lens: paso 7, imagen 3 de 3
    • The lens is only attached to the main camera body. Set the front and back covers aside.
    • Unscrew three screws from the outermost plastic plate covering the lens.
    • After the screws are removed, the outermost plate can be removed.
  8. Ricoh YF-20 Super Lens Replacement: paso 8, imagen 1 de 3 Ricoh YF-20 Super Lens Replacement: paso 8, imagen 2 de 3 Ricoh YF-20 Super Lens Replacement: paso 8, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Remove the ring shaped metal brace.
    • Using fingers or tweezers, remove the lens from the camera.
Conclusión
Eric Dazet
Miembro Desde 04/10/12
352 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-21, Amido Spring 2012 Miembro de Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 10
Ultimos 30 días: 14
Todo El Tiempo: 658
