Saltar al contenido principal
Ricoh YF-20 Super Lens Cover Replacement
Qué necesitas
  1. Ricoh YF-20 Super Lens Cover Replacement, Front Cover: paso 1, imagen 1 de 2 Ricoh YF-20 Super Lens Cover Replacement, Front Cover: paso 1, imagen 2 de 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Lens Cover Replacement: paso 2, imagen 1 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 2, imagen 2 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 2, imagen 3 de 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Lens Cover Replacement: paso 3, imagen 1 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 3, imagen 2 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 3, imagen 3 de 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Lens Cover Replacement: paso 4, imagen 1 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 4, imagen 2 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 4, imagen 3 de 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Lens Cover Replacement: paso 5, imagen 1 de 2 Ricoh YF-20 Super Lens Cover Replacement: paso 5, imagen 2 de 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Lens Cover Replacement: paso 6, imagen 1 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 6, imagen 2 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 6, imagen 3 de 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: paso 7, imagen 1 de 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: paso 7, imagen 2 de 3 Ricoh YF-20 Super Lens Cover Replacement, Lens Cover: paso 7, imagen 3 de 3
    • The lens cover is only attached to the front cover of the camera. Set the rest of the camera aside.
    • In order to reach the lens cover, the zoom mechanism must be removed.
    • Unscrew three screws from the front cover that hold the zoom mechanism in place.
    • Remove the zoom mechanism.
  8. Ricoh YF-20 Super Lens Cover Replacement: paso 8, imagen 1 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 8, imagen 2 de 3 Ricoh YF-20 Super Lens Cover Replacement: paso 8, imagen 3 de 3
    • Unscrew the five screws that hold the lens cover plate and metal brace in place.
    • Remove metal brace.
    • Remove lens cover plate.
  9. Ricoh YF-20 Super Lens Cover Replacement: paso 9, imagen 1 de 2 Ricoh YF-20 Super Lens Cover Replacement: paso 9, imagen 2 de 2
    • To remove lens cover, push the lens cover from the outside of the front cover towards the inside of the front cover.
    • Remove the lens cover.
    • The metal arm attached to the lens cover is not securely attached and may fall off.
Conclusión
Eric Dazet
Miembro Desde 04/10/12
352 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-21, Amido Spring 2012 Miembro de Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 1
Ultimos 30 días: 3
Todo El Tiempo: 313
