Saltar al contenido principal
Ricoh YF-20 Super Button Mechanism Replacement
Qué necesitas
  1. Ricoh YF-20 Super Button Mechanism Replacement, Front Cover: paso 1, imagen 1 de 2 Ricoh YF-20 Super Button Mechanism Replacement, Front Cover: paso 1, imagen 2 de 2
    • Use the screwdriver to unscrew the indicated screws from the left, right, bottom, and back sides of the camera.
  2. Ricoh YF-20 Super Button Mechanism Replacement: paso 2, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 2, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 2, imagen 3 de 3
    • Loosen the back cover from both the left and the right sides of the camera. Take off the back cover.
    • The lid of the battery compartment may fall off because it is not attached to anything.
  3. Ricoh YF-20 Super Button Mechanism Replacement: paso 3, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 3, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 3, imagen 3 de 3
    • Open the film compartment.
    • Press your finger on top of the grey latch on the left side of the camera.
  4. Ricoh YF-20 Super Button Mechanism Replacement: paso 4, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 4, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 4, imagen 3 de 3
    • Removing the film compartment door is optional. However, it may aid maneuverability in future steps.
    • Use a thin object like a toothpick or a small screwdriver to push down on the metal pin holding the film compartment door in place.
    • Use your fingers to completely remove the metal pin.
    • Remove the film compartment door.
  5. Ricoh YF-20 Super Button Mechanism Replacement: paso 5, imagen 1 de 2 Ricoh YF-20 Super Button Mechanism Replacement: paso 5, imagen 2 de 2
    • Use a thin shaft screwdriver and unscrew the two indicated screws within the film compartment.
  6. Ricoh YF-20 Super Button Mechanism Replacement: paso 6, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 6, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 6, imagen 3 de 3
    • Loosen the front cover from the left and right sides of the camera.
    • Take off the front cover.
  7. Ricoh YF-20 Super Button Mechanism Replacement, Buttons: paso 7, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement, Buttons: paso 7, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement, Buttons: paso 7, imagen 3 de 3
    • Remove and set the front and back covers aside
    • Unscrew the screw that holds the front plate brace in place.
    • Take out the brace.
  8. Ricoh YF-20 Super Button Mechanism Replacement: paso 8, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 8, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 8, imagen 3 de 3
    • Unscrew the four screws keeping the front face plate in place.
    • The top left screw also holds a metal clip in place.
    • Remove metal clip.
  9. Ricoh YF-20 Super Button Mechanism Replacement: paso 9, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 9, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 9, imagen 3 de 3
    • After removing the metal clip in the previous step, the front face plate can be removed.
    • The front face plate is attached to the camera body by two small wires. Carefully remove the plate and completely separate it from the camera body.
  10. Ricoh YF-20 Super Button Mechanism Replacement: paso 10, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 10, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 10, imagen 3 de 3
    • Unscrew the two screws that hold the button mechanism in place.
    • Press down on button mechanism to unlatch it from the camera body. When pressed down, the bottom of the mechanism should push outward.
  11. Ricoh YF-20 Super Button Mechanism Replacement: paso 11, imagen 1 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 11, imagen 2 de 3 Ricoh YF-20 Super Button Mechanism Replacement: paso 11, imagen 3 de 3
    • Lift the button mechanism up carefully, removing the spring at the top of the mechanism from where it is attached to the camera body.
    • Take out the button mechanism.
Conclusión
Eric Dazet
Miembro Desde 04/10/12
352 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 6-21, Amido Spring 2012 Miembro de Cal Poly, Team 6-21, Amido Spring 2012
CPSU-AMIDO-S12S6G21
4 Miembros
18 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 29
Todo El Tiempo: 1,108
