Saltar al contenido principal
Ricoh Theta S Outer Case Replacement
Qué necesitas
  1. Ricoh Theta S Outer Case Replacement, Outer Case: paso 1, imagen 1 de 1
    • Wedge the spudger underneath the small plastic square located on the bottom of the device.
    • Move the spudger to remove the plastic cover.
  2. Ricoh Theta S Outer Case Replacement: paso 2, imagen 1 de 2 Ricoh Theta S Outer Case Replacement: paso 2, imagen 2 de 2
    • Remove the four 3-mm screws located on the bottom of the device. You will need to use the Phillips 00 screwdriver.
  3. Ricoh Theta S Outer Case Replacement: paso 3, imagen 1 de 3 Ricoh Theta S Outer Case Replacement: paso 3, imagen 2 de 3 Ricoh Theta S Outer Case Replacement: paso 3, imagen 3 de 3
    • Insert the plastic opening tool in between the panels shown.
    • Apply pressure to unlatch the 9 spring clips located around the perimeter of the device.
    • Lift the panel from the device.
Conclusión
Bradley Sutton
Miembro Desde 11/07/17
737 Reputación
4 Guías creadas
Equipo
IUPUI, Team S3-G1, Harley Fall 2017 Miembro de IUPUI, Team S3-G1, Harley Fall 2017
IUPUI-HARLEY-F17S3G1
3 Miembros
4 Guías creadas
Un comentario
Where can find spare part case?
Thanks
Franco - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 19
Todo El Tiempo: 2,168
