Saltar al contenido principal
Ricoh Super 8 800z Film Cartridge Hooks Replacement
Qué necesitas
  1. Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: paso 1, imagen 1 de 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: paso 1, imagen 2 de 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement, Film Cartridge Hooks: paso 1, imagen 3 de 3
    • Open the device's film cartridge door by pulling the release switch towards the eyepiece.
    • Lay the device with the left side down and the door open to allow access to the film cartridge hooks.
  2. Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 2, imagen 1 de 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 2, imagen 2 de 3 Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 2, imagen 3 de 3
    • Using a Phillips #000 screwdriver, remove one of the screws from the rotating hooks in the center of the film bay.
    • Be sure to hold down the opposite side of the hooks with a finger to prevent it from spinning.
  3. Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 3, imagen 1 de 2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 3, imagen 2 de 2
    • Now put your finger on the side of the screw you just removed, and take out the remaining screw with a Phillips #000 screwdriver.
  4. Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 4, imagen 1 de 2 Ricoh Super 8 800z Film Cartridge Hooks Replacement: paso 4, imagen 2 de 2
    • Using your fingers, gently remove the film cartridge hooks.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 228
