Saltar al contenido principal
Ricoh Super 8 800z Eyepiece Adjuster Replacement
Qué necesitas
  1. Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: paso 1, imagen 1 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: paso 1, imagen 2 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement, Eyepiece Adjuster: paso 1, imagen 3 de 3
    • Remove the rubber covering from the eyepiece by slowly pulling down on the cover from any direction.
  2. Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 2, imagen 1 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 2, imagen 2 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 2, imagen 3 de 3
    • Use Phillips #000 screwdriver to remove the three screws around the eyepiece lens.
    • Remove the metal plate from the eyepiece.
  3. Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 3, imagen 1 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 3, imagen 2 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 3, imagen 3 de 3
    • Turn the adjustment ring counter clockwise until it is as close to the lens as it will go.
  4. Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 4, imagen 1 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 4, imagen 2 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 4, imagen 3 de 3
    • Remove the screw on top of the back panel of the camera using a Phillips #000 screwdriver.
    • Use a plastic opening tool to lift the plastic covering to reveal a screw underneath it.
  5. Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 5, imagen 1 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 5, imagen 2 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 5, imagen 3 de 3
    • Continue to hold the plastic covering back with the plastic opening tool.
    • Use a #1 flathead screwdriver to remove screw in the oval opening beside the eyepiece. Be careful not to drop the screw into the camera body.
  6. Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 6, imagen 1 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 6, imagen 2 de 3 Ricoh Super 8 800z Eyepiece Adjuster Replacement: paso 6, imagen 3 de 3
    • Slide the eyepiece adjuster out of the camera body.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 14
Todo El Tiempo: 292
