Saltar al contenido principal
Ricoh Shotmaster 130Z Zooming Lens Replacement
Qué necesitas
  1. Ricoh Shotmaster 130Z Zooming Lens Replacement, Zooming Lens: paso 1, imagen 1 de 1
    • Set the dials to "A" (Auto), and Off mode.
    • You will not be able to move these dials once the case has been opened.
  2. Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 2, imagen 1 de 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 2, imagen 2 de 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 2, imagen 3 de 3
    • Remove the 5 Phillips screws from the sides and the back.
  3. Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 3, imagen 1 de 2 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 3, imagen 2 de 2
    • Remove the 5mm JIS #00 screws from the bottom of the camera.
    • Pay attention to the 6mm screws on the sides of the tripod slot, as they are a slightly different size from the rest of the screws. However, you still may use a J00 screwdriver to remove them.
  4. Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 4, imagen 1 de 2 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 4, imagen 2 de 2
    • Using an opening tool, lift the case of the tripod slot (on the bottom) until the back portion of the case is released.
    • Continue to use the the opening tool to insert it and lift right next to the strap of the camera.
    • This will release the front portion of the case.
  5. Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 5, imagen 1 de 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 5, imagen 2 de 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 5, imagen 3 de 3
    • Use a JIS #0 screwdriver to remove the three marked screws found around the perimeter of the lens.
  6. Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 6, imagen 1 de 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 6, imagen 2 de 3 Ricoh Shotmaster 130Z Zooming Lens Replacement: paso 6, imagen 3 de 3
    Herramienta utilizada en este paso:
    Comprar
    • Proceed to remove the two screws using a JIS #00 screwdriver.
    • Use tweezers to lift the lens off of the board.
Conclusión
Equipo
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 15
Todo El Tiempo: 529
