Saltar al contenido principal
Ricoh Shotmaster 130Z Battery Replacement
Qué necesitas
  1. Ricoh Shotmaster 130Z Battery Replacement, Battery: paso 1, imagen 1 de 1
    • First, make sure that the camera is turned off. The dial must line up the word "off" with the white tally mark.
  2. Ricoh Shotmaster 130Z Battery Replacement: paso 2, imagen 1 de 2 Ricoh Shotmaster 130Z Battery Replacement: paso 2, imagen 2 de 2
    • You can find the battery compartment on the side of the camera. Search for the arrow and the abreviation "BATT"
    • Stick your finger nail (or a blue opening tool if you wish) in the notch and flip open the door to expose the battery compartment.
  3. Ricoh Shotmaster 130Z Battery Replacement: paso 3, imagen 1 de 3 Ricoh Shotmaster 130Z Battery Replacement: paso 3, imagen 2 de 3 Ricoh Shotmaster 130Z Battery Replacement: paso 3, imagen 3 de 3
    • The yellow latch holds down an extra cover for the batteries
    • Push on it in to open the compartment
    • Insert batteries according to the charges marked on the inside part of the cover
Conclusión
tcalvin12
Miembro Desde 10/25/16
153 Reputación
1 Guía escrita
Equipo
UMass Dartmouth, Team 3-4, Isaacson Fall 2016 Miembro de UMass Dartmouth, Team 3-4, Isaacson Fall 2016
UMASSD-ISAACSON-F16S3G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 628
