Saltar al contenido principal
Rexing V1P Plus Rear Camera Replacement
Qué necesitas
  1. Rexing V1P Plus Rear Camera Replacement, Rear Camera: paso 1, imagen 1 de 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: paso 1, imagen 2 de 3 Rexing V1P Plus Rear Camera Replacement, Rear Camera: paso 1, imagen 3 de 3
    • Begin by orienting the rear camera lens facing up.
    • Twist the adhesive mount surface parallel to the camera lens.
    • Pull the mounting ring axially away from the camera case.
  2. Rexing V1P Plus Rear Camera Replacement: paso 2, imagen 1 de 3 Rexing V1P Plus Rear Camera Replacement: paso 2, imagen 2 de 3 Rexing V1P Plus Rear Camera Replacement: paso 2, imagen 3 de 3
    • Locate the small indentation on the camera case previously covered by the mounting ring.
    • Insert a spudger in the case seam and twist it to lever open the camera case.
    • Use the spudger to pry the case the rest of the way open.
    • Remove the top casing from the rear camera.
  3. Rexing V1P Plus Rear Camera Replacement: paso 3, imagen 1 de 2 Rexing V1P Plus Rear Camera Replacement: paso 3, imagen 2 de 2
    • Remove the camera and camera motherboard from the casing.
    • Flip the camera board over revealing the two 3.5 mm screws on the back holding the rear camera to the board.
  4. Rexing V1P Plus Rear Camera Replacement: paso 4, imagen 1 de 3 Rexing V1P Plus Rear Camera Replacement: paso 4, imagen 2 de 3 Rexing V1P Plus Rear Camera Replacement: paso 4, imagen 3 de 3
    • Remove the two 3.5 mm screws securing the camera to the motherboard using the Phillips #00 screwdriver.
  5. Rexing V1P Plus Rear Camera Replacement: paso 5, imagen 1 de 1
    • With the screws removed, the rear camera can be separated from the motherboard.
Conclusión
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 13
Todo El Tiempo: 216
