Introducción
This tutorial shows how to connect to the Digitech Jamman Solo debug port. It can be used to diagnose the pedal or even to rewrite a new firmware if the pedal internal memory got corrupted.
The pedal in the tutorial was not giving any sign of life except the main LED turning green at boot for one second, then turning off.
Qué necesitas
Before starting, plug your pedal to a computer using an USB mini B cable.
If your device is detected (for instance in Peripheral Manager for Windows users, with "lsusb" for Linux users)
Install the JamManager software from here
Try updating the firmware using JamManager
If your device is not detected, or if the firmware update fails, carry on with this tutorial
Unscrew the 3 jack connectors bolts
Lift the board from the top of the pedal
Unscrew the 2 Torx T15H holding the SD card
The board can be moved out of the pedal
Spot the debug UART port
Under the button when looking from the top
Marked as "P3" when looking from the bottom
UART connection requires to connect TXD, RXD and GND
Solder a 3V3 USB-UART adapter to the pins by following this pinout
GND connected to the adapter GND
TX connected to the adapter RX
RX connected to the adapter TX
Connect to the USB-UART adapter using an appropriate software
PuTTy on Windows machines
Screen or Minicom on Linux machines
The serial parameters are: 115200, 2N1, no flow control
Once everything is connected, you can plug the 9V power supply to the pedal
It should display startup messages
Afterwards, it should give you a prompt with the possibility to interact with it
Try typing "ls"
If possible, ask a friend to do the same with a working pedal
On the working pedal, with the USB-UART probe and with an SD Card inserted, type:
etfsctl -d /dev/etfs2 -r /mnt/sdfs/etfs2.structured.bin
cp -r /mnt/nandfs/* /mnt/sdfs/nandfs_copy
Otherwise, recover the files from the Internet
Copy them from your computer to the SD card
Insert the SD card with the working files in the device and run:
etfsctl -d /dev/etfs2 -S -e -w /mnt/sdfs/etfs2.structured.bin -c
Once it is done, power cycle the device and checks if it works
If it is still missing files, run:
cp -r /mnt/sdfs/nandfs_copy/* /mnt/nandfs
Power cycle and verifies the device is working
To reassemble your device, unplug it, unsolder the usb-serial adapter, and follow these instructions in reverse order.
