Introducción
After long term use of the Revlon One-Step Hair dryer, the filter may become blocked with debris which could result in limited airflow. Therefore, this guide will help users to replace the lint filter.
Qué necesitas
First, remove the pink panels on each side of the handle in order to access the screws.
Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
Next with your free hand carefully pull the cord out of the port of the dryer handle.
Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
3 personas más completaron esta guía.
Un comentario
I' just fixed mine following your instructions.. Thanks a lot for the share.
