Saltar al contenido principal
Revlon One-Step Hair Dryer Barrel Replacement
Qué necesitas
  1. Revlon One-Step Hair Dryer Barrel Replacement, Barrel: paso 1, imagen 1 de 1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Barrel Replacement: paso 2, imagen 1 de 3 Revlon One-Step Hair Dryer Barrel Replacement: paso 2, imagen 2 de 3 Revlon One-Step Hair Dryer Barrel Replacement: paso 2, imagen 3 de 3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Barrel Replacement: paso 3, imagen 1 de 3 Revlon One-Step Hair Dryer Barrel Replacement: paso 3, imagen 2 de 3 Revlon One-Step Hair Dryer Barrel Replacement: paso 3, imagen 3 de 3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
Conclusión
3 personas más completaron esta guía.
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 11
Ultimos 30 días: 37
Todo El Tiempo: 1,368
