Saltar al contenido principal
Revlon One-Step Hair Dryer Air Inlet Replacement
Qué necesitas
  1. Revlon One-Step Hair Dryer Air Inlet Replacement, Barrel: paso 1, imagen 1 de 1
    • First, remove the pink panels on each side of the handle in order to access the screws.
    • Use the iFixit opening tool to remove the pink panels.
  2. Revlon One-Step Hair Dryer Air Inlet Replacement: paso 2, imagen 1 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 2, imagen 2 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 2, imagen 3 de 3
    • After removing the pink panels, there will be one visible screw on each side of the dryer handle measuring at 11mm.
    • Carefully unscrew both of these screws with a tri-point Y000 screwdriver.
    • Next, completely remove the screws out of the dryer handle.
  3. Revlon One-Step Hair Dryer Air Inlet Replacement: paso 3, imagen 1 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 3, imagen 2 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 3, imagen 3 de 3
    • Remove the barrel by twisting and pulling it away from the handle of the dryer.
    • Before attempting to take the barrel off, make sure the dryer powered completely off and is cool to the touch.
  4. Revlon One-Step Hair Dryer Air Inlet Replacement, Cord and Plug: paso 4, imagen 1 de 2 Revlon One-Step Hair Dryer Air Inlet Replacement, Cord and Plug: paso 4, imagen 2 de 2
    • Next, slide down the air inlet and the setting dial to reveal the 11mm screws on each side of the handle at the bottom of the hair dryer.
  5. Revlon One-Step Hair Dryer Air Inlet Replacement: paso 5, imagen 1 de 1
    • There will be one visible screw on each side of the dryer at the bottom of the handle, measuring at 11mm.
    • Store screws in a safe place, you will need them to reassemble the device later.
  6. Revlon One-Step Hair Dryer Air Inlet Replacement: paso 6, imagen 1 de 1
    • Place the iFixit opening tool along the seams of the handle and pry the two pieces apart.
  7. Revlon One-Step Hair Dryer Air Inlet Replacement: paso 7, imagen 1 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 7, imagen 2 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 7, imagen 3 de 3
    • Once you have exposed the inside of the dryer, you will see a clear port at the very end where the cord is connected and plugged into.
    • Now, with your thumb and pointer finger gently pinch the top and bottom of the clear port.
    • Next with your free hand carefully pull the cord out of the port of the dryer handle.
  8. Revlon One-Step Hair Dryer Air Inlet Replacement, Setting Dial: paso 8, imagen 1 de 1
    • Once the cord is disconnected from the handle, you should be able to slide the dial setting off completely and free it from the cord.
  9. Revlon One-Step Hair Dryer Air Inlet Replacement, Lint Filter: paso 9, imagen 1 de 1
    • Remove the air inlet by sliding it completely off of the wire.
  10. Revlon One-Step Hair Dryer Air Inlet Replacement: paso 10, imagen 1 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 10, imagen 2 de 3 Revlon One-Step Hair Dryer Air Inlet Replacement: paso 10, imagen 3 de 3
    • Take the lint filter out from the air inlet by peeling it from the sides.
  11. Revlon One-Step Hair Dryer Air Inlet Replacement, Air Inlet: paso 11, imagen 1 de 1
    • Once the lint filter is detached from the plastic filter protector, you can now replace it.
Conclusión
Una persona más ha completado esta guía.
Un comentario
"Slide down the linlet" I've been trying to twist and pull it in every direction possible but it won't come off. How do you just "slide" it down? my type is the RVDR5222
Mar - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 8
Ultimos 7 días: 38
Ultimos 30 días: 156
Todo El Tiempo: 4,379
