Saltar al contenido principal
Revlon 473 Heating Element Replacement
Qué necesitas
  1. Revlon 473 Heating Element Replacement, Shell: paso 1, imagen 1 de 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Heating Element Replacement: paso 2, imagen 1 de 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Heating Element Replacement: paso 3, imagen 1 de 3 Revlon 473 Heating Element Replacement: paso 3, imagen 2 de 3 Revlon 473 Heating Element Replacement: paso 3, imagen 3 de 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Heating Element Replacement, Heating Element: paso 4, imagen 1 de 1
    • The heating element is the group of tightly coiled bronze wires behind the vent hose as well as the silver coils.
    • Make sure that there are no breaks or debris obstructing the wires of the heating element.
  5. Revlon 473 Heating Element Replacement: paso 5, imagen 1 de 1
    • To test the heating element, use a digital multimeter.
    • Set the multimeter to 200 under ACV.
    • Bring the ends of the multimeter toward the two lead wires.
    • If the circuit between the wires is closed, the numbers on the multimeter should keep changing.
    • If the numbers are not changing, replace the heating element.
    • If the circuit is closed, check the thermal cutout.
Conclusión
Jessica Leyva
Miembro Desde 09/18/12
143 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-5, Propen Fall 2012 Miembro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,874
