Saltar al contenido principal
Revlon 473 Hair Dryer Switch Replacement
Qué necesitas
  1. Revlon 473 Hair Dryer Switch Replacement, Shell: paso 1, imagen 1 de 1
    • Before disassembly, make sure that the device is unplugged.
    • Remove the two 17.83 mm black screws located on the handle.
  2. Revlon 473 Hair Dryer Switch Replacement: paso 2, imagen 1 de 1
    • Separate the shell from the main component.
    • Check to ensure each piece is free from debris.
  3. Revlon 473 Hair Dryer Switch Replacement: paso 3, imagen 1 de 3 Revlon 473 Hair Dryer Switch Replacement: paso 3, imagen 2 de 3 Revlon 473 Hair Dryer Switch Replacement: paso 3, imagen 3 de 3
    • Remove the casing from the heating element.
    • For reassembly, reattach the silver casing before the black cover.
  4. Revlon 473 Hair Dryer Switch Replacement, Switch: paso 4, imagen 1 de 1
    • Locate the two switches in the handle of the device.
  5. Revlon 473 Hair Dryer Switch Replacement: paso 5, imagen 1 de 1
    • Set the multimeter to 200 ACV.
  6. Revlon 473 Hair Dryer Switch Replacement: paso 6, imagen 1 de 1
    • Bring the probes toward each switch to test for continuity.
    • If the numbers on the multimeter continue to change, the circuit is closed and the switches are functioning.
    • If the meter stays at a set number, the circuit is open, and the switch needs to be replaced.
    • To replace a faulty switch, cut the wires and solder the wires back on to the new switch.
Conclusión
Una persona más ha completado esta guía.
Jessica Leyva
Miembro Desde 09/18/12
143 Reputación
5 Guías creadas
Equipo
Cal Poly, Team 1-5, Propen Fall 2012 Miembro de Cal Poly, Team 1-5, Propen Fall 2012
CPSU-PROPEN-F12S1G5
3 Miembros
5 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 31
Todo El Tiempo: 1,818
