Introducción
- CAUTION: Battery repair/modification can be dangerous. Exercise caution when following this guide. DO NOT EXPOSE LITHIUM ION BATTERIES TO WATER OR FLAMES.
All batteries have a lifespan. For example, when a phone's battery capacity is below 80%, the phone's battery life will become very short. It’s necessary to replace the new battery with a new one. For old batteries, simply throwing them away is a waste and can pollute the environment. Batteries are made from a number of materials including acid, lead, nickel, lithium, cadmium, alkaline, mercury, and nickel-metal hydride. When battery disposal is not handled correctly, the battery can leak, potentially contaminating the soil and water, and possibly harming human health. Therefore, REWA will share a way to convert old phone batteries into a power bank, turning trash into treasure.
Terminology: Anode = Positive terminal, Cathode = Negative terminal
Qué necesitas
Resumen del Video
We are using old batteries from the iPhone 7 Plus and iPhone 8 Plus. Peel off the tape on the battery protector off with tweezers.
Apply tin to the anode and cathode of the battery with a soldering iron at 365°C. Heat to remove the protection board.
Measure the battery voltage with a multimeter. The voltages of the two batteries we have are 3.66V and 3.76V respectively.
Anode (Positive terminal)
Cathode (Negative terminal)
We are combining a 2900mAh iPhone 7+ battery with a 2675mAh iPhone 8+ battery and turning it into a 5575mAh power bank.
Apply double-sided tape to the battery and align the anodes and cathodes of the two batteries.
Solder together the anode and cathode of each battery with a soldering iron at 365°C.
Measure the voltage with a multimeter. Ensure the voltage is 3.7V.
Get a red wire and a black wire. Strip each end of both wires to expose the copper wire and apply tin on the copper wire with a soldering iron at 365°C.
Next, solder the red wire to the anode and the black wire to the cathode.
Solder the anode of the battery to the anode of the power board.
Solder the cathode of the battery to the cathode of the power board.
Press the button. For this project, the power bank is 33% full.
Apply foam to secure the battery.
Install the middle frame to the housing and put on the bottom plastic cover.
Connect the phone to the power bank. The phone can be charged.
Connect the charger to the power bank. The power bank can be charged too.
If you have extra old batteries, you can increase the capacity of the power bank by combining more old batteries. Give it a try and leave a comment of your results.
8 personas más completaron esta guía.
3 comentarios
Do the batteries automatically stop charging at full? Like can I add iPhone batteries to the powerbank I already have?
@rewatech Hey, would you mind adding the power bank frame and board you bought as a required part? This guide might not work if people don't know what parts you are using
I think they reused an old power bank and just swapped out the batteries and that this guide can apply to most off-the-shelf power banks
tayola -
