Saltar al contenido principal
Retro-Bit Retro Duo Controller Button and Pad Replacement.
Qué necesitas
  1. Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): paso 1, imagen 1 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): paso 1, imagen 2 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement., Buttons and Pads in Controller(s): paso 1, imagen 3 de 3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After screw removal, carefully lift the controller casing.
  2. Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 2, imagen 1 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 2, imagen 2 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 2, imagen 3 de 3
    • Pinch the top and bottom of the shoulder pads, then lift out.
    • There are small elastic pads below each shoulder pad. Replace these if they are not functioning correctly.
  3. Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 3, imagen 1 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 3, imagen 2 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 3, imagen 3 de 3
    • Carefully lift the circuit board from the controller case.
  4. Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 4, imagen 1 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 4, imagen 2 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 4, imagen 3 de 3
    • To replace the action button pad, lift this part out.
    • Lift the Select and Start button pad.
    • If replacing the D-Pad, lift this pad.
    • Pinch and lift the shoulder button pads.
  5. Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 5, imagen 1 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 5, imagen 2 de 3 Retro-Bit Retro Duo Controller Button and Pad Replacement.: paso 5, imagen 3 de 3
    • Support the controller face and push buttons toward the inner case.
    • Use care. The buttons have a tiny tab to keep them in place.
    • Support the controller face and push the D-Pad toward the inner case.
Conclusión
Evelyn
Miembro Desde 09/25/17
223 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S4-G4, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 20
Todo El Tiempo: 1,188
