Saltar al contenido principal
Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement
Qué necesitas
  1. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): paso 1, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): paso 1, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement, Circuit Board in Controller(s): paso 1, imagen 3 de 3
    • With the controller on its face, remove the five 6 mm Phillips #1 screws.
    • After removing the screws, carefully lift the controller casing .
  2. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: paso 2, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: paso 2, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: paso 2, imagen 3 de 3
    • Pinch the top and bottom of the shoulder buttons and lift them out.
    • Below each shoulder button, there are small elastic pads. To remove them, pinch the pads and slide them out.
    • Removing the elastic pads allows easier circuit board access.
  3. Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: paso 3, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: paso 3, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board in Controller(s) Replacement: paso 3, imagen 3 de 3
    • Carefully lift the circuit board from the controller case.
Conclusión
Evelyn
Miembro Desde 09/25/17
228 Reputación
2 Guías creadas
Equipo
USF Tampa, Team S4-G4, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
Miembros de 3
10 Guías creadas
0Guía Comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 8
Ultimos 30 días: 15
Todo El Tiempo: 1,162
