Saltar al contenido principal
Retro-Bit Retro Duo Circuit Board Replacement
Qué necesitas
  1. Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: paso 1, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: paso 1, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board Replacement, Circuit Board: paso 1, imagen 3 de 3
    • With the console on its top, remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Simply remove the sticker before screw removal.
    • Flip the console on its feet. Carefully lift the top casing from the back (where the AV/S and power ports are).
    • To avoid damage, do not remove the top casing completely. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Circuit Board Replacement: paso 2, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board Replacement: paso 2, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board Replacement: paso 2, imagen 3 de 3
    • Remove the one 6 mm Phillips #0 LED circuit board screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Circuit Board Replacement: paso 3, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board Replacement: paso 3, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board Replacement: paso 3, imagen 3 de 3
    • Remove the 11 screws holding the circuit boards and ports in place.
    • Six 11 mm Phillips #2 holding the circuit boards.
    • Three 12 mm Phillips #2 screws holding the controller ports.
    • Two 7 mm Philllips #2 screws holding the back ports
  4. Retro-Bit Retro Duo Circuit Board Replacement: paso 4, imagen 1 de 3 Retro-Bit Retro Duo Circuit Board Replacement: paso 4, imagen 2 de 3 Retro-Bit Retro Duo Circuit Board Replacement: paso 4, imagen 3 de 3
    • Carefully lift the circuit board while holding either the AV or controller ports. Alternatively, you can hold the circuit board on its edges.
    • Make sure to lift the circuit board completely out of the bottom case.
    • To avoid damage, do not to touch the top or bottom faces of the circuit board.
Conclusión
Truong Vo
Miembro Desde 09/25/17
320 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S4-G4, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Miembros
10 Guías creadas
Un comentario
I hope you show the second part were you replace the 72pin connector. Please include part source.
The 72 pin connector grabs too tightly on the cart.
Thanks.
George Tedrick - Contestar
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 28
Todo El Tiempo: 2,434
