Saltar al contenido principal
Retro-Bit Retro Duo Cartridge Doors Replacement
Qué necesitas
  1. Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: paso 1, imagen 1 de 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: paso 1, imagen 2 de 3 Retro-Bit Retro Duo Cartridge Doors Replacement, Cartridge Doors: paso 1, imagen 3 de 3
    • With the console on its top. Remove the four 12 mm Phillips #2 screws.
    • There may be a sticker covering one or more of the screws. Remove it before the screws.
    • Flip the console on its feet, pinch near the AV/S ports, and carefully lift the top casing.
    • Do not completely remove the top casing. There is a small LED circuit board connected to the main circuit board.
  2. Retro-Bit Retro Duo Cartridge Doors Replacement: paso 2, imagen 1 de 3 Retro-Bit Retro Duo Cartridge Doors Replacement: paso 2, imagen 2 de 3 Retro-Bit Retro Duo Cartridge Doors Replacement: paso 2, imagen 3 de 3
    • Remove the one 6 mm Phillips #0 screw.
    • Lift the top case and set aside.
  3. Retro-Bit Retro Duo Cartridge Doors Replacement: paso 3, imagen 1 de 3 Retro-Bit Retro Duo Cartridge Doors Replacement: paso 3, imagen 2 de 3 Retro-Bit Retro Duo Cartridge Doors Replacement: paso 3, imagen 3 de 3
    • Remove the eight 10 mm Phillips #0 screws.
    • The cartridge doors are spring-loaded and may pop up.
  4. Retro-Bit Retro Duo Cartridge Doors Replacement: paso 4, imagen 1 de 2 Retro-Bit Retro Duo Cartridge Doors Replacement: paso 4, imagen 2 de 2
    • Carefully lift the cartridge door case and set aside.
  5. Retro-Bit Retro Duo Cartridge Doors Replacement: paso 5, imagen 1 de 2 Retro-Bit Retro Duo Cartridge Doors Replacement: paso 5, imagen 2 de 2
    • Take the cartridge doors out of the top casing.
    • Keep the correct cartridge doors together. Note the door numbers and position.
    • Doors numbered two and four are for NES cartridges.
    • Doors numbered three are for SNES cartridges.
Conclusión
Truong Vo
Miembro Desde 09/25/17
320 Reputación
3 Guías creadas
Equipo
USF Tampa, Team S4-G4, Eyestone Fall 2017 Miembro de USF Tampa, Team S4-G4, Eyestone Fall 2017
USFT-EYESTONE-F17S4G4
3 Miembros
10 Guías creadas
0 comentarios
Agregar Comentario
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 2
Ultimos 30 días: 18
Todo El Tiempo: 586
